Evo 9 Shatters/shakes when turning left or right
I own a Evo 9 and discovered a month ago that when coming from a full stop, 1st gear, turning left or right, as i apply power the car gets this annoying shattering/shaking that seems coming from the front. I do not feel anything when going straight. Is there anyone out there that had a similar problem? This is driving me nuts and any ideas would help.
I don't imagine it's the cv joint if it's making a shaking and dragging noise. The CV would be a constant knocking. Agreed on change your fluid and see if it helps, but it does sound like a diff issue to me.
This may sound stupid but check to make sure that all your lugs nuts are tight, seriously.
I had someone put my suspension on my car and they didnt make sure all my lugs were tight and it was doing something similar to what you are describing and the lugs were loose.
The rear diff has a clutch type posi system. If there isn't enough additive in the oil the clutches may act like you describe. I suggest you try the diaqueen in the rear. We know that works.
Problem Fixed
Well i am never diverting from Diaqueen again. Replaced Redline fluid in reardiff with OEM fluid and everything went back to normal. Unbelievable, that fluids can make a car act crazy... Thanks to all of you for some great troubleshooting..
Well, now you know the importance of owning a vehicle supported by a forum. Don't drive without it.
Deathbox
Jul 15, 2015 07:48 PM
RalliMark
Nov 5, 2013 09:38 AM
WickedWhtMR
32
Oct 19, 2006 03:38 PM
