2.3L Stroker owners; what are your idle / cruising AFR's?
Im started reading up on AEMPRO and been going through the options and reading through the AEMPRO Guide.
Currently reading the "economy tuning" thread, and just wanted to see what afr's the 2.3L stroker owners are running at idle and at cruising. This thread isnt going to be a pissing contest at who's setup is CORRECT or PROPER. I just want to see what people run, and what are some safe afr #'s for a stroker.
My current setup; evo8 ][ 2.3l, 272/272 cams, 35r, 1000cc's...
Idle : 1050rpm _ AFR's 14.8:1
Cruise : 3000-3500rpm 13.5:1 [highway]
Exactly what he said. Now at idle, when you have really big cams that pull very vary low vacumn having a little rich idle 13.0-14.0 can help steady out the idle and keep the stumble/lope out of the car.
Currently only running open loop only so had to adjust idle to 13.6-13.9 due to colder weather, and 15.0-15.5 cruising seems to work. Once i get it hooked up for closed looping i can do more adjusting.
Im confused to hell when it comes to rpm idle adjust ;/
Thats next on the list, and thanks for ur posts/info
Dj
Dj
Raceghost
Jun 1, 2016 12:30 AM
ezzey
Jul 19, 2012 07:41 PM
