Starting problems round 2
I have been having starting problems for a long time now with my car.
Changed starter nope, polished the crap out of the terminals on the batt and starter nope, had the battery checked at advanced (genesis small batt) chked out ok to them.
It cranks over fine like 2 out of 3 times. when it doesn't start i just put it in reverse and push and pull the car back and forth. this makes it start in one shot, sometimes turning the key over a few times does it.
IDK what else to chk, i am guessing its the battery what do you guys think?
If it was the cable then why does rocking it help? There's something else going on..mayb with a sensor. Crank angel or cam angel might be faulty. So when you turn the key it cranks just doesn't fire correct? So your either missing fuel or spark or both. Check to see if your getting any of tha when the no start occurs. That will narrow it down alot
How tight did make the bolts on the starter to the trans. Sometimes if you put them on too tight the starters wont work to well. Try losening it a tiny bit and see if that helps.
ok i know where to start on this one. on your starter you have a big power cable and 1 one wire on the solenoid . first make sure you have a good connection at the solenoid with the small wire it could be broken at the plug or something.
if there is no issue there. (do this when your car is not starting) disconnect the small wire on the solenoid and grab a volt meter check to see if you have power at the wire when you are turning the key over.
if you dont you either have a broken wire barley making contact or a loose connection at the relay for the starter. or the starter replay could just be bad.
i almost grantee this is whats happening. thats why moving the car helps . it moving the wire giving it contact.
if you really do hear it click then there is no reason what so ever the starter should not turn over. replace your replay its only a few bucks. but i personally think its in that wire somewhere. i dont think that wire is getting signal to your starter to tell it to turn over
