Need some advise for timing belt job.
I have an evo 9 and it's time for the timing belt job. I would definitely try to save some money on this job. What should I really change when it comes to the timing belt job. Remember! i wanna go conservative. I don't beat on my car. Always take it easy. Any advise on this would be appreciated. Thanks guys
just replace the timing belt and balance belt. if the water pump and the hydrolic tensioners look fine i would not replace them but make sure you do at the next timing belt service. everything else you can change yourself like plugs, wires, drive belt etc. when need be.
its not an easy job for a 1st timer but it isnt rocket science do your homework first get your tools and stuff ready and you should be able not to bend valves by taking your time and do it right the first time
A search turned up these 2 threads:
https://www.evolutionm.net/forums/ev...placement.html
https://www.evolutionm.net/forums/ev...-belt-how.html
