Where to find crank "sensing blade"?
So, apparently my crankshaft sprocket bolt backed out enough for things to wiggle around, my position sensor fell out of my lower timing cover in pieces when I took the cover off, and my timing belt and balance shaft belts are pretty much shredded. The wheel behind the crankshaft sprocket that the position sensor sits above is all jacked up too. The manual refers to it as the "crankshaft sensing blade", but I've tried searching with a few other names and came up empty. Where can I get this part?
On a side notes, if I'm trying to tighten that bolt down, what's the "correct" technique to keep the engine from turning over? Maybe I'm having a brain fart, but I don't know. TIA.
EvolutionRacing
Jun 1, 2016 08:12 PM
LCyangster
Aug 26, 2014 05:32 AM
anthonypazsd
Jan 31, 2010 04:01 AM
