Need Inspection But "Seonsors NOT Ready"
#31
which software did you use to access the OBD setting? Thank you
Hi: I am having the same problem with "3 sensors not ready" (Cat, O2, o2 heater) while trying to get my car inspected, I was wondering which software did you use to access the OBD sensor setting as shown in this posting by you? My car was tuned last year by Melon, and I think he used the Tephra mod, because I have the flashing CEL for knock indication after the tune. Thank you.
Who did your flash? You can easily set everything to "ready" in the tune depending on what is or is not enabled in your ECU. Contact a tuner on the site or wait for one to chime in. I'm sure for a small fee one would take the time to update your ROM and set all the stuff to ready. What do you have emissions wise on your car? What isn't reading ready? o2? cat? egr? e-mail me your rom file - mattheww1978@hotmail.com and I'll take a quick look, it's very easy to set up...
#32
can you look at this rom?
Can you look at this ROM to see if my ODB sensors for Cat/O2/o2 heater are off? Thanks
=05blue8;8773318]Who did your flash? You can easily set everything to "ready" in the tune depending on what is or is not enabled in your ECU. Contact a tuner on the site or wait for one to chime in. I'm sure for a small fee one would take the time to update your ROM and set all the stuff to ready. What do you have emissions wise on your car? What isn't reading ready? o2? cat? egr? e-mail me your rom file - mattheww1978@hotmail.com and I'll take a quick look, it's very easy to set up...[/QUOTE]
#33
Rather than start a new post, I have the same situation as the OP.
I have a downpipe -> cutout -> stock catback
No CELs are on
All sensors are in place although I don't know what's turned on or off.
The only NOT READY lights that come on according to OBD system check is catalytic converter efficiency and EGR (turned off since EGR is removed). 02 and Heated 02 are both READY. I have an 02 simulator on the car. What would cause the cat efficiency to be NOT READY?
No CELs are on
mitsubishimanny
Evo X How Tos / Installations
42
Mar 11, 2015 04:45 AM
bnr34rb26dett
Nov 21, 2010 07:18 PM
