High horsepower low bank accounts.
Here is what I plan on doing:
Shep stage 3 Transfercase:
Shep built tranny:
Buschur stage 3 2l short block:
Ported head with oversized valves:
Hta 3586 or 3582 turbo kit with tubular manifold:
Double pumper and high z 1650 injectors
Big Cams
Bigger intercooler and pipes then what I already have.
There will be much more of course, but you get the idea.
Shep built tranny:
Big Cams
Shep built tranny:
Big Cams
Shep built tranny:
Big Cams
You should do a LR2.4 with a TS 3586. You will spool at 4500 and pull all the way to 8600+. that is what I plan on doing. it would be a sick daily or you could do a 3582 for even more bottomend however you will be limited to 700. I really like my Black but I want 700+daily.
Mikey
Mikey
I just want to give and idea to the noobs of what it will cost to build an either A) stock appearing street car, speed rocket, etc or B) a fully built, wild, omgWTFkindaEvoisthat car. That's all this thread is intended to do, people can also post there experiences and compare cheap parts to more expensive ones. Whatever, I just wanted to help the n00bs.
This thread is to give an idea of build cost; and or house a database with enough builds that you can find a similar one to what your dream build consist of. It also dual serves to show what parts are commonly used to reach what hp goals. You can press control+f on the first page type in a part name and see how many builds it shows up in.
I thought it would be a useful thread, if you and lots of other people think otherwise I am totally ok with it being deleted. Just thought I'd provide more insight amongst new users and current users.
Mikey
Mikey
![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
