Pros v. Cons.........Bushings
Dam! I didn't realize that you had a IX...I scanned the thread quickly. Having said that, we have so many cable bushings for so many cars that I'm sure we have something here that would fit. If you would be interested in doing some mini development for us, and you wanted to check some measurements and dimensions of the stock ones, we could see if we would have anything for the Evo IX guys.
Sorry about the confusion.
Patrick
Team TWM Performance
Patrick
Would love those bronzoil ones for my IX! lol
I've ran buschurs for about a year now, just glob on copper anti-seize and it should do just fine. I just took a look at them two days ago when installing my mini battery and they're doing just fine with lots of anti seize still on there, even after a michigan winter.
Absolutely lube them. I greased my Buschur aluminum bushings and they were seized and were a PITA to get out and causing shifting issues (this was after 4 years and I never re-lubed them fyi). I used multi-purpose automotive grease which I thought would be fine. I guess I should have used a different type. I switched to Delrin bushings. Tell Caramon I said hi.
I'm using the WORKS/Kartboy underhood shifter bushings and shifter assembly poly bushings. The shifter assembly made a bigger difference IMO. I have never needed to lube them up or service them and they have been performing flawlessly. This is on an evo VIII. You can buy the Works if you want blue, or Kartboy if you like neon green. They are the same thing though.
If I do not have to relube them often I think it would be worth it as my evo is no longer my dd and is garaged. I just want to make sure they will not lock up on me out of the blue
So you didn't use anti-seize just normal grease? I think the metal bushings might be the best but if they require extra maint. that others do not it might be a draw back.
you recognize the name
Kracka
83
Jan 20, 2017 12:54 PM
