Emissions testing
Emissions testing
So in my county in IL we have to go to emissions testing every year, sadly. I currently have a 3" tbe with a test pipe... my question is, do you think I will pass emissions? I'm going to have it tuned before I go and will have the rear o2 turned off and all codes cleared and what not.
I do currently have the stock cat back system, but someone wants to buy the muffler. So I'm wondering if they will allow me to do the emissions test with out a muffler? Just the pipe right after the second resonator....
if they do a sniffer test youll never pass.
the obd2 plugin test is simple to pass with the proper patches on the ecu to disable the rear o2 and make it still look ready.
you will most likely need to buy a hi flow cat.
If you do the anti-fouler fix which extends the rear o2 a bit, you will pass emissions. Just make sure you have no codes or anything for a while. I passed IL emissions with full turbo back w/ test pipe with this fix
Also do not go to a full service emissions testing facility, only go to the ones that can only scan.
Agreed. No matter what mods you put on the car as long as there's no SES light you'll pass. Unless they no the sniffer test, then car won't pass. At time of testing I had turboback/no cat, walbro 255, licp and no tune yet. Was very nervous, exhaust fumes smelt very bad. No SES light=Pass
I live in CT and I went to emissions with a 3 inch turbo back with no cat and the guy came out and said i passed and i was amazed. I have no idea how i passed without a cat.. maybe the guy liked my car or something, but nothing was hooked up to the exhaust they just plugged something in the obII port and revved it a couple times.. It amazed me that i passed with no cat on.
You can't just clear the codes anymore (or anymore here). If they try to scan your car after clearing, it'll come back as saying "incomplete" which means it was neither pass nor fail. Just means it hasn't went through it's cycles yet. You have to let it go through it cycles first by driving the car for a few days and then see if the SES light comes back on. If it doesn't you pass. If it does, keep trying.
I said that I know of.. so thats an opinion.. and we are talking about an 'actual' sniffer test?????????????
NOT obd-II plugin
and in addition, your vehicle has a large cat STOCK for a reaon, there are many levels of emission testing and each state also has their own requirements aka 50state legal etc...... w/ no cats your car has basically ZERO emission controls (evap still counts)... mufflers are only there to lower db's.
NOT obd-II plugin
Do you think they will allow me to do the test if I don't have a muffler? Like if I just bolt up the stock cat and cat-back but the muffler would be cut off. I believe the one in town does the sniffer test btw
If you go to a shop that does not have a lift, or a sniffer, you can get away no problem. If they have a lift, they can do a visual test, and they will see a straight pipe where the cat is supposed to be. If they have a sniffer, well, then it may or may not pass, it is a gamble.
