Shell build up
Old Nov 12, 2010 | 09:27 AM
makizm69's Avatar
Talking Shell build up
i am planning to buy a shell probably 8 or if i get lucky 9. never owned an evo but had 2 integras, i built a type r from scratch and it was a lot of fun until it got stolen so now i want to get my hands on something different. not for track just tastfully moded daily maybe weekend car
my main concerns is how are the parts interchangeable between different years? like if i had a 2003 and want to have 2006 seats, door panels, steering wheel, wheels, bumpers, lights... etc
does it worth looking for shell newer than 2003, other than being newer?
also, what would be a good stock motor/trans?
im not new to how forums work so please don't tell me where search is located, i want to build up post counts too so i could start using marketplace sooner
Old Nov 12, 2010 | 09:33 AM
heel2toe's Avatar
Sounds like it should be a fun project. Evos VII - IX are all the same CT9A chassis thus all the parts should be interchangeable.
Old Nov 12, 2010 | 09:35 AM
evo8426's Avatar
basically everything can be swapped between the 7-8-9, the only thing that doesnt would be the camshafts and headgasket. other than those 2 things i believe everything else can be interchanged
Old Nov 12, 2010 | 09:36 AM
Dallas J's Avatar
Veteran: Army
Not really sure you'd be better off with a Shell than a complete car. Evos are still new enough that with the exception of blown drivetrain parts, a shell might be hard to come by.
Man up and just buy an IX, its got all the goodies
Old Nov 12, 2010 | 09:41 AM
Earthen's Avatar
Platform is the same, but the parts are not all interchangable. Depends on what motor you will use (2.0, 2.1, 2.2, 2.3, 2.4). Most of the parts you will be able to use regardless from an 8 or 9.
Examples:
Mivec vs non
ACD vs non
5speed vs 6speed
Old Nov 12, 2010 | 09:56 AM
RockmanX's Avatar
Examples:
Mivec vs non
ACD vs non
5speed vs 6speed
Thank you for the above post the others have alot of mis information in them. The items he listed are important factors and to be honest to build one up could cost you alittle more then just buying one thats already cheap.
Old Nov 12, 2010 | 09:57 AM
06MRV8Killer's Avatar
Mike from AWD Motorsports has this...
2003 Evo VIII Rolling Shell.. Clean Title w/ 50miles.. 15k approx Miles on Chassis.. Pics to come.. 7500.00
Old Nov 12, 2010 | 11:01 AM
makizm69's Avatar
Examples:
Mivec vs non
ACD vs non
5speed vs 6speed
good info! Sounds like ill have to do some research on the motors. but as far as mivec, ACD is if the chases comes already equipped for that i will keep it there otherwise less electronics is my way to go since i like to control the car and not the car telling me how to drive it :P
to buy one as a whole is not fun and i would need a bigger budget at once, when you get it bare bones you build it the way you want to be and enjoy the process, plus you get to know the car very well
for now i have 350z which will have to go soon because it doesn't really satisfy me. so my option number two is if i find someone before i buy a shell with a clean evo who's willing to do a trade, i will do that
Old Nov 12, 2010 | 11:28 AM
evo8426's Avatar
only 1 post has misinformation, when it comes down to it almost everything is interchangable.
either transmission can be run, all suspension can be used, interiors can be changed, body parts can swap. any catback can be used but the downpipe will be different if you have acd or not. if you have the wiring harness for an 8 then you run the non-mivec motor which will decide on which stock ecu you use, and camshafts will be different depending on if you get the mivec motor or not. hope this helps you
Old Nov 12, 2010 | 12:26 PM
makizm69's Avatar
that makes sense, im assuming 9 is the only one that came with mivec so if i get 8 i don't have to worry about it just have to make sure the motor is not mivec
is acd a separate piece of electronic or it's inside the ecu? and what else it ties into, like trans, steering, driveshaft, brakes..?
since u mentioned about ecu, is there any reflash versions for the ecu if you run with common mods?
Old Nov 12, 2010 | 01:16 PM
Earthen's Avatar
If all you are getting to start is a shell, then it doesn't matter what the build is yet. You can go with a stock 8 or 9 build, a fully built or custom.
The key thing here is you still can't just buy any parts and not worry about compatibility. You need to decide on a build to determine what key components you will need that may be required to what you want.
Don't let anyone tell you that just getting any major part will work.
Old Nov 12, 2010 | 02:16 PM
Sil'vr-Boi6's Avatar
Transfercase clears the only thing you have to worry about-which isn't a prob. anyhow
Most of the parts are interchangeable. Just make sure the exhaust system that you fit/buy in their will clear your transfercase.
Old Nov 12, 2010 | 02:29 PM
Murf's Avatar
I believe I just saw a thread by AWD performance where Mike was selling an evo 8 shell.
Old Nov 12, 2010 | 02:44 PM
MMMR0820's Avatar
Good luck man.....btw if you need a stock Evo IX sterring wheel lemme know I have a stock one with an air bag for sale.....shoot me a pm
Old Nov 13, 2010 | 09:16 AM
MattC28's Avatar
I did this with a 91 stealth es and converted it to a 94 3000gt vr4. That was a lot of fun, I am sure you will enjoy it.
I just traded that car for an evo 8, so hey, all that work was worth it, even after I got bored of the car!
Quick Reply: Shell build up
