Front Wheel Drive? Help?
Registered User
Ok so i bought a evo which was t boned into the 2 doors on the passenger side. The damage isnt to bad. Point is the drive shaft or differential was removed and idk why?
It was just the rear diff and it was all in the back seat of the car and with the bolts?
So when i came to pick up the car at the auction i put the car into 1st gear and slowly drive it like 5mph to the get to drive it up the trailer. Then i found out it wont make it up bc its just slipping. So my question is was it the clutch or something to do with the rear diff not being hooked up. So i take the tranny of and take a look at the clutch and it looks like it still had like 30-40% life left. The flywheel was pretty worn out and the pressure plate seemed fine . Also as i unloaded the car of the trailer to drive it into the garage, i put it into 1st again and was driving like 5mph and then just floor it and the rpms's go up to 7k and the car just stands there? So overall i was just wondering is it safe since that diff is out? And why is it out? And does it have anything to do with slipping?
I just dont see why it would be the clutch bc it looks like it still have a good amount of life left?
Any help would be greatly appreciated, i searched but never got my answer, so thanks and let me know.
someone might of jacked the driveshaft and rear diff... probably because they knew it was going to the auction... got any pics of the damage and what the underside looks like. might help us help you out..
Registered User
Oh but you see, i have the diff? And with all the bolts? They were in the back of the car? No one stole em. Yea ill get pics up sooner or later. Im gonna have a little refinishing thread. And transfer case is there and everything. I will get pics up soon to make the story easier to understand.
Registered User
Yea ive already thought of that one also. Then i was thinking since the clutch was slipping so bad if it was the clutch he may have converted to front wheel drive so it would have less stress. Its just my main question is, if you remove the drive shaft ( the diff) and its front wheel drive will the tranny have some type of setup for slipping? Bc if so im changing my clutch for nothing and i went through hell.
If the rear drive is removed all the rotating motion will go to the rear - path of least resistance. The viscous coupling should lock, allowing you to move some. However, if the car has been driven this way for a while, the viscous coupling could be toast too. Anyway, after the rear drive is connected, if nothing else is broken, the car should drive normally. The viscous coupling is important when trying to get unstuck in snow but otherwise has little effect.
kazx9r
Sep 6, 2013 09:04 PM
akeric
17
Jul 16, 2011 09:10 AM
