Blew my motor!! so much for the FP Black on the stocker!
#33
I definitely do not consider the evo x an upgrade. They went away from what the evo was originally designed to be and turned it into a more friendly/comfortable car.
I can understand the movement financially, but for no other reason. That being said, I would love to see an evo x RS that came in at around 3000lbs.
Back on topic though...looks like the OP is a good candidate for a 4g64 block and either a destroked 2.1 or 2.4
#34
#36
My rod exited through the block in the same manner on number 4. Seems that is the rod that likes to chuck most frequent. My rod bolts were still firmly attached to the bottom section of the rod left on the crank. No sign of bearing or fastener failure. E-85 with a FP OG 'green'.
Oh btw...415 whp & 400 wtq on a MD . Lasted a couple years though....lol
In the process of getting a built 2.4L installed in my IX RS. GLW your build.
#42
Another jersey guy haha sorry to hear about your car...where were you on the parkway? I was out doing pulls around 12am at exit 138... oh man were you right by the clark exit? i think i passed by you as i was doing some pulls..there were like 3 troopers there?
anyways good luck with the build...im waiting till my engine does so i have an excuse for a 2.4l
Thats the plan!!
I wouldnt drive an X if it was given to me. Just not my style. And theres not ONE thing in the X that id consider an "upgrade".
Saw the flames thru the hood scoop. I think it was just the oil burning.. it was only flaming for about 2 or 3 minutes.
Got the motor completely out today. Theres another hole just as big in the back. #4 rod is gone!! Im going to add pictures very shortly.
#43
Well, heres some pictures of the last two days work. Got the trans pulled yesturday thanks to the step by step on EvoMoto!! Anyway, got the out, and pulled the motor out today. Everything is labled, and has markings for all the harnesses. Ive decided that im ditching the AC, so ill have a couple of parts for sale at a later date.. On with the pictures!!
more to come!
more to come!
