Exedy Twin blown up plates ?
Hey everyone!
I recently recommended and installed an Exedy Twin to a car. Evo 8, bolt-ons, pumpgas, 24 psi - so no overkill on power there. I personally did the break in of the clutch (~500ish miles of baby driving, tons of shifting) and after that the owner of the car continued for another 500 at least.
Fast forward ~8000 miles:
Symptoms:
car won't go to gear when turned on
soft pedal
clutch still engages when in gear by using pedal and is drivable (somewhat) and not slipping
Mechanic opens it and gives me a ring:
Plates measured: 0,1 - 0,2mm of plates used
Springs and center metal part of the plate completely F*ed up on the bottom plate and showing sever damage on the top one also on the springs.
What can be the cause of this ? The owner of the cars quote "I didn't launch it more than 10 times" and otherwise normal high speed beating.
The clutch was installed professionally, broken in properly and also installed with a new throw out bearing.
The main question is: What can cause damage like this? How? Anyone with similar experience?
Thanks!
Edit: Pics of the damaged plate
![](https://img576.imageshack.us/img576/6456/img0352a.jpg)
Symptoms:
soft pedal
Thanks!
![](https://img251.imageshack.us/img251/6452/img0351ki.jpg)
this usually happens when the transmission is inserted or removed partially, engaging the input shaft into the clutch discs, but not the dowel pins or any of the bolts & the transmissions weight is not supported. this puts a lot of side loading on the clutch plates as they are supporting the weight of the entire transmission.
this is more common on dual plate clutches as sometimes the plates dont align perfectly even with the tool, so you get the trans in halfway past the first disc & it gets stuck trying to engage the 2nd disc that is out of alignment, if your not using a proper trans lift your arms get tired fast & people typically let it hang for a second to rest thier arms, this is where the damage is done.
a typical sign of this is unequal wear on the clutch plates as the disc will typically bend & it will wear half of the plate on one side & do the same 180 degrees on the opposite side & it is usually the transmission side disc
You'd be surprised how understanding Exedy can be. I blew a hyper single back in the day, then a twin sd, and talked with them. They gave me a killer deal on a triplecerametallic. Something like $1400 shipped. You should definately call them and talk to them. A very reputable company with great customer service.
