AMS exhaust users please chime in
I bought an AMS exhaust off a forum member here and im having problems with the axle back portion lining up.
This is how the axle back portion sits with the 2 hanger mounts installed and hooked up. It is indeed touching my bumper.
This is a Torque solution hanger mount, and its pulled as far as it can go. It seems I still need another inch of room.
This is the rear stock hanger mount and you can see it is pulled towards the rear of the bumper.
I don't understand why Its not fitting correctly. The AMS exhaust hasn't seem to be modified and neither the mounting points of my car. I had an HKS exhaust previously and didnt have this problem before.
Any ideas on why this isnt fitting correctly?
Thanks
Thanks
I'm pretty sure the JDM one is shorter so it doesn't stick out on a JDM rear. That looks like a normal USDM one. But it's definitely not supposed to fit like that. From the pictures you can't really see why it's like that. Try playing with the rubber mounts?
i didnt think of it that way, but are the hangers fighting eachother or are they stretched and tweaked because he had to force the exhaust to sit where its at in the cut out in the bumper? i dont know if that made much sense lol, i guess what i'm trying to say is if you took the bumper off would the hangers line up like they should? if so then it's the bumper, and maybe the hangers still but if you take it off and they are still flubarbed then it's the hangers for sure. i'm not saying take off the bumper you should be able to tell if they would straighten out if the bumper wasn't putting them on a bind.
The mount by the rear diff is fighting by the way it's stretched it still needs another inch to go. The mount by the bumper is wanting the exhaust to move towards the engine and is not the problem. I'll take more pics of what I'm talking about when I'm home. I don't see why I would have to cut and reweld the hanger on the exhaust because it hasn't been modified before
http://www.torquesolution.com/Torque.../ts-eh-m11.htm
This is the mount you're supposed to have.
The poly hanger you have on now with the HKS mount should be for the mounting in the wheel well.
Thanks alot! I ordered the whole Torque solutions exhaust mounts, but it came with no instructions, so I just put the mounts on through trial and error.
Unfortunatly the kit came with three 12mm mounts and no 14mm mount, so I have to use my stock one for the rear hanger.
Also I'm not selling the HKS mount, Ill be selling it with my exhaust once I decide to clean it up and put it up for sale.
