Radio Relocation Fail...
So I was so excited to get the Radio Relocation kit and Gruppe-S HVAC panel.
I installed it and moved the radio down to the lower cubby with 0 problems.
When I try to put in the 3 52MM Prosport gauges that I just bought I ran into a very annoying problem and wondering if anyone has found a solution to it. On the cutout on the farthest right of the Gruppe-S panel, when I insert my gauge it won't sit flush with the panel. I think it is getting caught on the right most spot of where the Radio used to mount (in the OEM position).
How can I go about fixing this so my gauge sits flat? I would really like all 3 Prosport gauges in that Panel, but if I have to I'll move my AEM Uego there (since it's a bit short in length than the Prosports).
Also, when I turned on the car the Oil Temp was sitting right around 100 and not moving at all. Do you think the gauge is reading incorrectly? Or did I just not give the car time to warm up and the temperature to rise?
Thanks for your help guys and I really can't believe I'm the first person to run into this problem.
The problem with the right side gauge mounting hole on the Gruppe-S panel has been problematic for a lot of us. There have been several previous posts. My solution was to remove the metal radio bracket (it can be unbolted), and then cut away the part that blocks the gauge, and reinstall. Other members cut it away without removing it. Still others managed to bend it out of the way. Take your pick.
The oil temp gauge is probably okay. It will read whatever temperature the oil is at when you start the car. Just make sure that all of the gauges are grounded really well. If you are installing any digital gauges, I would use individual grounds (not connected to to the same screw, etc.) for each gauge. That is AEM's recommendation, and what I did on my install. Seems the AEM wideband in extremely sensitive to sharing a common ground, even with other AEM gauges.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
As for my grounding issue, I grounded the aem uego to a separate bolt, then grounded the other 3 ProSport gauges to another bolt.
Also out of curiosity what is the average oil temp and oil pressure for our cars?
I ran into the same problem with mine. Although, rather than using the supplied mounting bracket for the gauge furthest right (towards the passenger) you can just use double sided tape. I put the supplied tape from Prosport around the gauge and gave it a snug shove into the Gruppe-S panel. It should work out alright. Not exactly the solution I was looking for when I did my research but it works and honestly holds as good as those metal brackets they give you.
The only thing I can think is that I was using 60mm gauges from their Premium lineup. And I had the 60mm Gruppe-S panel. But it should be very similar nonetheless.
imma sound like an echo here but yea, i've dealt with that same problem...+1 on just bending it slightly enough to allow the gauge to fit...but still keep it with little bend as possible just in case you do decide to put the radio back at top, you can just bend the bracket back
The lowest reading the gauge reads is 100 deg so thats where it sits at. Once the temps start to rise beyond that it should move accordingly. How long did you leave the car running when you said the guage wasnt responding? IMO I just cant see having an issue with sharing a common ground with all 3 gauges, so long as the ground is good.
[quote=mx4life85;8938928]Thanks for your help sir. I looked at removing the radio bracket but couldn't figure out how. I didn't see anything holding it in place....[quote]
The part of the radio bracket which is interfering with the right side gauge is attached with two (or three?) screws. They're a bit awkward to get to, but you can do it. Again, you can just bend the bracket out of the way rather than remove it.
I'll do my best! (There is some white stuff on the ground here believe it or not...so I have to brave that, haha)
Yeah, that's what I did at least. If I get the chance I'll go pop mine off and take a quick picture so you can see what I did on my install. It may not be the best way or even the right way...but it's what I figured was the only way to mount them to keep from moving all around.
Travisivart190
16
Aug 12, 2015 05:43 PM
shrtstuff89
11
Apr 10, 2011 07:16 PM
CWhiteRun
For Sale - Cars For Sale
Oct 15, 2009 07:37 PM
