start up question - check engine light supposed to come on?
I have a 2004 GSR. When you guys turn the key to start the car, does the CEL turn on for a brief moment before starting?
Are you serious? Logically doesn't make any sense but i'm desperate enough to try. Which o2? front or back?
Thanks. I think I have an issue with my car, my CEL doesn't turn on when turning the key.
I have an 06 and I just tried this to get you an answer and all of the lights including the check engine came on for a couple seconds and then turned off... hope that helps.
do all your other lights come on or is it just the ses light that doesn't come on?
You can check the ses light by disconnecting like your maf plug for a brief moment...that should trigger the ses light.
You need to calm down. I just tried to specify the model just so there isn't any kind of confusion. It's amazing what people on forums post on threads these days.
I just checked with my obd-2 reader and was able to get a soft code for p0335 (crank position sensor).
Thanks to everyone who responded to my question. I suppose I need to replace my bulb as well as the CPS.
[QUOTE=rino;8940054]all the lights come on except for the CEL. I'll try the maf trick and see if triggers from there.
Im having the same problem,i just got my evo a couple of days a go.Found out there was no bulb,went to mitsu got a new one and still doesn't work WTF
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
ashspark101
04-06 Lancer Ralliart How To Requests / Questions / Tips
29
Jul 25, 2014 07:43 PM
JesseOZ
Lancer Tranny/Drivetrain Tech
20
Jun 3, 2014 04:10 PM
RalliMark
Nov 23, 2011 06:51 PM
mitsuevodriver
Jul 21, 2010 04:51 AM
