Harness Bar Seatbelts
Im looking to put in schroth 4 point harnesses in my evo ix mr. I ordered a harness bar and im just confused on what schroth 4 point harnesses i buy to go into my evo with out taking out my stock seatbelts. Please help im lost on this and want to get them soon, thank you
Schroth ASM 4 Point Harness
Now onto the harness bar. From experience these harness bars can come with extremely low grade hardware, for something in charge of keeping you alive in an accident I would ensure the nuts and bolts are of good quality. Also, it is a major pain in the *** to keep the stock 3 point belt installed along with the harness bar (depending on how the harness bar attaches). If I wear serious about wanting a harness bar, I would ditch the OEM 3 point belt.
This leads me to ask why you want a harness bar to begin with? If you are wanting your *** more firmly planted in your seat, I'd recommend a CG Lock.
http://www.cg-lock.com/index.html
These are pretty sweet, hold you very well and are much safer (and cheaper) than an improperly installed harness bar/4 point harness. If you still want the harness bar, ensure that you follow installation instructions of the Schroth harness to the letter as anything less and your life could be in danger in an accident. I have seen some very, very sketchy harness bar installations and it is not worth the risk, especially for a daily driver.
Dan
yea im getting schroth 4 point asm's im just curious what kind wraps around the harness bar to hold the shoulder straps because theres bolt in and like latch in ones. How and which ones go and wrap around the harness bar
Both the Profi II ASM and Profi II ASM FE are designed to wrap around the harness bar and bolt to the floorboard of the car.
Here is a video teaching how to wrap a harness bar properly.
The difference between the FE and regular is the regular is cam lock, and hence nicer, and the FE is more like a regular seat belt latch.
Once the belt is wrapped properly, the lap belts need to be bolted to the floor boards with a reinforcement plate behind the sheet metal. Keep in mind that all belts need to be angled properly, but it sounds like you are thinking things out pretty well.
Dan
Dan
LV///R
Apr 13, 2017 10:06 AM
pulley1fan
Jul 2, 2007 12:52 PM
