Blown fuse on positive battery terminal
Old Dec 29, 2010 | 10:24 PM
J8dailo's Avatar
i was working on car last night and accidentally touch the positive terminal with a wrench and blew the fuse in it..i know i should have disconnected battery but thought i can work around it... i called dealership regarding the part...the told me the fuse is a seperate part for the positive terminal but from with i see its built in.. can someone fill me in so i can order the right part..thanks
Old Dec 29, 2010 | 10:28 PM
EvoJoeIX's Avatar
heres what you need
Be sure to check your build date
before 7/04:
https://www.lancershop.com/customer/...productid=2976
after 7/04:
https://www.lancershop.com/customer/...cat=216&page=1
Old Dec 29, 2010 | 10:31 PM
05VIII's Avatar
Not built in just screwed it. Has to be special order too, no one will carry it. I did the same thing
Old Dec 29, 2010 | 10:41 PM
yellowrocket's Avatar
yeah man i did the same thing years ago special order part at dealership car will run but battery wont charge. order the part asap!!!!!
Old Dec 30, 2010 | 12:06 AM
vipers's Avatar
i blew the acd fuse on mine... just used a little solder and she was good as new has worked great for almost a year now
Old Dec 30, 2010 | 12:57 PM
J8dailo's Avatar
i was thinkin bout soldering the fuse for few days til the part comes in cause i know the reason why it blew, from me grounding it by accident...still debating if i should do that or will it cause other problems because it is my daily
Old Dec 30, 2010 | 02:31 PM
J8dailo's Avatar
i guess my soldering skills not too good and it doesn't work..i removed and bypass the fuse to see if my alternator still good..im getting 14.6v so alternator is charging...would it be a problem for me to drive with bypassing the fuse to my local dealer which is 30min away to pick up the part? they have it in stock
Old Jul 26, 2013 | 05:12 PM
TheClaw's Avatar
Been having the 3 lights issue on my ACD for years now. Finally just realized the 60a on the terminal was blown. Car feels much better with working ACD...actually getting lock out of my diff mod now.
Old Jul 26, 2013 | 06:45 PM
Tuxevo's Avatar
Just buy a new fuse from mitsu. It's 8 bucks.
Old Nov 5, 2013 | 01:41 PM
RallyAve's Avatar
Question Battery fuse and power loss issues; At a loss, please help
02 lancer...positive terminal battery fuse blew and piece broke...both dealerships dont have part in stock....bought a 100amp stereo inline fuse to replace the piece that broke...will this work? Dont have the original mounting bracket or fuse so I want to make sure amperage is right....dont know where or how this drain is happening....havent drove my car in months, new battery, new alternator, new cables and cleaned and tightened grounds....battery still dies over night...and no my radio nor lights are on....the ol interweb is useless and this seems to be where I always resort to...ya'll have helped before, looking for some guidance from some experienced mitsu techs. Thanks guys.
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 09:41 AM
lbwilliams44
Jul 6, 2020 04:32 AM
DecBro
May 17, 2017 08:14 AM
Robdeep3
Jul 29, 2013 02:53 PM
Dragking2189
Jan 10, 2010 10:26 AM
