5th gear grind
5th gear grind
this grinding just started lately after my trip to the drag strip...........normal shifting=grind, fast shifting=more grind.......however really slow shifting that takes 3-4 sec to put it in gear!lol!=no grind
all other gears are perfect.
is it the syncros?
is it the syncros?
Most likely yes, but may I suggest Doing this.
If you are pulling the trans for a rebuild might as well go to town. We have the Stage 2 service done on our car and the quality is very impressive.
Dan
Dan
Just get a stock rebuild kit replacing all the synchros, download the evo manual, grab a couple of ![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
, do it yourself. You're just going to want to have a hydraulic press to pull off/install the gears on the input and output shaft. I did mine by myself (and I'm a noob on anything trans related) and it came out perfectly.
I had good experience with it. my car had redline in it, started getting very notchy, boarderline grinding in 3rd and 5th, when the cold weather came. put in the amsoil and it is like a new trans. I would recommend it
I had gear grind for quite a bit of time and thought it was the syncro's never replaced them, one day my clutch died and when I replaced the clutch the grind was gone for good... So if u have a bad clutch and tob that could be your issue
