Boost creeping in 6th gear
Old Dec 31, 2010 | 08:29 AM
mitsuclipsegsx's Avatar
Evo mr with AMS, 3 TBE( high flow cat),k&n cone, custom tune, NO MBC, set to 23psi. In 6th gear when I floor it, it creeps to 26psi, what could cause this, the tbe??
Thanks
Old Dec 31, 2010 | 08:33 AM
TxEvo8's Avatar
The load on the car in 6th gear at lower rpms. If you put it into 6th gear at say 130mph, you probably would not see 26 psi..
Old Dec 31, 2010 | 08:43 AM
milford's Avatar
if your boost is controlled by the ecu using a tephra rom i believe you can set one of the tables lower so your ecu pulls fuel sooner if you exceed certain amount of load. or you can set your CEL to flash if you encounter any knock ..this way you know to get off the gas on your low rpm wot pulls
Old Dec 31, 2010 | 08:54 AM
Thanks for the info, I mean it should be fine since ams tuned it, just wanted to make sure.
Old Dec 31, 2010 | 08:56 AM
Come to think of it, this summer, I would shift into 6th doing 80 or 90 and it would creep to 26...
Old Dec 31, 2010 | 10:59 AM
EvoJoeIX's Avatar
stop flooring it in 6th gear
down shift if you need to be in boost 80-90 is only 3rd gear on a 6 speed, your making your car work harder then it has to
Old Dec 31, 2010 | 02:52 PM
LimitedSlip7's Avatar
Are there issues with stock wastegate size when upgrading intake, exhaust, etc? Any wastegate porting required to keep it in check?
honda-guy
136
Feb 13, 2013 10:59 AM
berns
54
Dec 15, 2010 01:42 AM
millsyy17
28
May 24, 2010 06:26 PM
keevo54
41
Nov 27, 2008 08:50 AM
hamflex
Feb 22, 2007 09:53 PM
Quick Reply: Boost creeping in 6th gear
