Car died after short gear pull!!!
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Ok so today I finished installing my walbro 255 and HTA FP Green I took the car out at around 12:00 am got to around 40 mph the steped on it IMIDEAtLy I poped the hot side pipe really loud bang and car died now car turns but won't start
I checked spark checked that the cams are turning fuel pump seems to be working and took battery off for around 3 mins still nothing.
Could it be that I had to cut then reconnect the o2 sensor on the o2 housing?
check your fuel pump, those lines can be a b*tch to snap in all the way, if their not snapped in completely they can pop off and voila your car wont start lol, hopefully its something as easy as this.
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
How are we supposed to know? You put the car together, are you not able to check the hoses yourself? We're here to help, but if you want the forums help you have to do your due diligence as well.
Bolting on a bigger turbo with stock injectors and going for a "I just installed a part and have no patience" WOT run, usually not a good idea. Check the turbo outlet pipe to licp and licp to intercooler connections first.
^ good question lol. the couplings and charge pipes have nothin to do with it starting u can drive the car with out a intercooler it just wont make boost. maybe vaccum lines tho. Yea dude u gotta be a nut to throw a green on and **** with out a tune and start hot doggin it haha. Also, make sure u didnt magicaly skip timing because anything could be possible right now.
Of course I checked all the hoses, clamps, and vacs, turned out to be the plug from when I changed the pump didn't clicked in hard enough and it fell, the pump did work but it was not delivering any fuel at all with stock injectors am still pretty damn rich from what I read on my wideband, I do have 1200's waiting to be install the day before tune hopefully next week
