Is the Air Filter snorkel needed?
Old Jan 15, 2011 | 07:47 PM
Thoe99's Avatar
When I switched over to an open element air filter, I got rid of the all the plastic boxing that was there, allowing much better access to other things in the engine bay. I left the snorkel on, since some people seemed to think that the air routed better to the filter.
I finally looked into this today and it seems like no air really flows to the snorkel. The opening of the snorkel is blocked by the hood's rubber dampener from direct air flowing towards it. So the intake system draws air in mainly by suction of surrounding air.
I'm thinking about getting rid of it cuz the foam on the snorkel is all brittle and breaking apart. So who thinks keeping the snorkel is still a good idea in this setup?
Attached Thumbnails Is the Air Filter snorkel needed?-2011-01-15-16.14.30.jpg   Is the Air Filter snorkel needed?-2011-01-15-16.09.04.jpg
Old Jan 15, 2011 | 07:52 PM
TeStUdO's Avatar
Fresh air does get to the snorkel, ask anyone who has had one of those rivets come loose and choke all the air flow to the engine.
Old Jan 15, 2011 | 09:57 PM
Thoe99's Avatar
That's only if they still have the whole intake box, right? In that case, I can see how the air only comes from the snorkel, but for my setup, air does not get pulled from the snorkel.
Old Jan 16, 2011 | 01:06 AM
SpoolinUp's Avatar
Silver Sponsor
Air does in fact make it through the snorkel, but it's advantage to a cone filter would be negligible since the system is no longer "sealed". I'd say its your call to take it or leave it.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 16, 2011 | 01:29 AM
D-Mon3y69's Avatar
I just took mine off
Old Jan 16, 2011 | 01:31 AM
dscevo8's Avatar
mine has been gone for awhile. It really hasnt affected me at all
Old Jan 16, 2011 | 01:52 AM
reboundicon's Avatar
I notice a fair bit of a difference after I put the snorkel on, but I am running with the stock airbox and apexi drop in. I previously did not have one for the airbox (previous owner removed it) and I felt less power than having it on. I know a lot of guys that left it, even with full intake set ups.
Old Jan 16, 2011 | 01:59 AM
BuBBasEVO's Avatar
i say remove it. its not giving you any gains being sealed. the filter itself will be sucking air in at every angle.. especially under boost.
Old Jan 16, 2011 | 03:57 AM
noypiC50's Avatar
Air doesn't go through under the hood where you're arrows are pointing but it goes through the mesh screen and through the rectangular opening right infront of the intake snorkel. You can see the rectangular opening in your second pic.
Old Jan 16, 2011 | 07:15 AM
ODUB's Avatar
might as well leave it. it doesn't hurt being there, and it does help a little.
Old Jan 16, 2011 | 10:56 AM
BoostINurI's Avatar
I used my snorkel until i got my ic piping in. Now it don't fit right so it's off...but it does work when on the car...i would leave it there.....your car tho
Old Jan 16, 2011 | 11:05 AM
nytalonTSi's Avatar
Mine was on for a while after the box was removed. But one day I just took it off cause it was in the way. I never put it back on though.
Old Jan 16, 2011 | 11:44 AM
EVO8emUp's Avatar
Data log some WOT pulls w/ and w/o the piece.
Old Jan 16, 2011 | 12:27 PM
TommiM's Avatar
With the stock airbox the snorkel does help suck in air, like a vacuum effect since its sealed. With an open element filter all the snorkel is gonna do is help guide in air that happens to get pushed through. It wouldnt hurt to leave it on and Im sure its still better than taking it off completely. It would direct outside air near the filter to help move away stagnant hot air, imo.
Old Jan 16, 2011 | 12:34 PM
EvoFredo's Avatar
the air never went in from right under the hood. it enters the space through the driverside upper grill opening. then up though the gap that is in the bumper and the core support. id say leave it on. i would have mine on except my radiator has the relocated neck and the snorkel no longer fits
Quick Reply: Is the Air Filter snorkel needed?
