"No Start" Conditions...any you can think of.
#31
Weak spark.
How do you know if its the spark plug or the coil pack?? It sounds like the spark is getting blown out after that initial crank...followed by fuel soaked plugs.
#32
The car sounds like the cam timing is off. It's cranks too smoothly if you will, like the starter doesn't have to work against compression. My car was two teeth off before and would not start. If you fuel coming out of the reuturn line I doubt it's a fuel issue. Also what you said about it if it was compression you would expect it to run on 2 cylinders, this is incorrect because cam timing has an effect on all cylinders. It doesn't effect them all the same and could possibly still run on a few cylinders but That all depends on where the timing ends up.
You can see the timing marks without removing anything, it is tricky to spot tho, you may want to take a look at a timing belt how to. Hope this helps
#33
#34
I definitely had a strong feeling toward timing, the only thing that had me stumped is, I've never seen a car go to a no start state due to timing then have the timing jump back to normal, for the car to idle and run fine. I did have the car WOT for a sec and it stumbled/"jerked" a little while I had the car depressed like something could have wrong with the . But it didn't throw any kind of lights.
#35
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
![](http://i101.photobucket.com/albums/m65/dom1013/9c800893.jpg)
![](http://i101.photobucket.com/albums/m65/dom1013/17093877.jpg)
It's almost like TOO much fuel is getting in and not enough spark at all...I didn't know timing could really do that. I have the manual, I need to see what I need to line up. Thanks on the input thus far.
#36
What's up guys, long time no talk!! Just giving an update on this one!
Had the compression checked at a GOOD shop, 1 GOOD 2 NO GOOD 3 GOOD 4 GOOD
I did notice the car empty on COOLANT when I bought it from the guy and I'm thinking it overheated enough to cause the damage it did. We realized the HEAD was WARPED! Right in between the cylinder #1 & 2 causing the head gasket not to seal properly :\
Idk if its the water pump that went out or car just not having any fluid in it. I wish I could have checked the water pump before I started tearing things apart!
The guy wants to mill the head to fix the issue.
-Head gasket / Studs / Water Pump recommendations?
It would actually push start and come on for a second, give it a little gas then it would die.
