Tial 50mm BOV problem with Evo IX
Hey all,
I'm having an issue with my 50mm Tial BOV. When trying to maintain a speed, lets say 50mph, when I let off the gas, the car surges and doesn't blow off as it should. I've taken the BOV and greased it, only to have the issue come back a few days later. Any ideas on what the issue could be? Also, I wanted to note that when the engine is cold upon start up, the BOV will surge under ANY level of boost until the car is fully warmed up. I took the BOV fully apart today and noticed that I have the standard unpainted spring. Apparently there is no way to adjust this BOV without purchasing another spring.
MODS LIST:
- DC sports downpipe
- Burschur catback
- AMS FMIC
- AGP LICP
- TurboTrix UICP
- Tial 50mm BOV
- EvoPowerMods external o2 dump
- Forced Performance 18psi wastgate actuator
- Turbo XS MBC
- Buschur Racing ported stock exhaust manifold
- Aeromotive high flow fuel rail
- Precision 1000cc injectors
- Warlboro high pressure fuel pump
- ACT street disc clutch
- ACT LightWeight flywheel
- ProSport Gauges (Boost, AFR, Oil pressure)
Thanks for your help guys....
Danny
MODS LIST:
- Burschur catback
- AMS FMIC
- AGP LICP
- TurboTrix UICP
- Tial 50mm BOV
- Turbo XS MBC
Danny
measure the vacuum you pull at idle, then goto tials website and order the right spring for the right amount of vaccum... easy as that
i will tell you now, that if you are on a MAF sensor, you are not gonna be able to keep the car from surging and have the blow off valve closed at idle. and thats all the spring does is keep it closed at idle
What you need to do is look at your vacuum reading at idle. Take that reading and compare that to the chart Tial provides for the proper spring to work. Also, have you been tuned with this BOV, or were you tuned then switched to this BOV. I ran this BOV on my car and had no issues what so ever after tuning. Also how old is the BOV? I would make sure you have the correct spring according to your vacuum reading, and also get tuned with it if you havent already done so.
Thanks,
What BOV's do you guys recommend with the stock MAF?....My car was tuned at 28PSI so I believe a crushed stocker is out of the question. I'd prefer aftermarket anyway.
Thanks,
Danny
Thanks,
Danny
Ok, check your vacuum, and see about getting the correct spring. I would look into a retune with the right one. You should not be having the issues you are having bro. If you have any other questions. Ask KevinD. He can help you out. He is a vendor on here. Evolution Dynamics.
