(CHECK ENGINE LIGHT) Catalyst system efficiency below threshold
Get the anti fouler from Ebay, put it in and clear the code. Simple as that. It's your cheapest solution and most likely your problem.
When you've done that, then come back and fill us in
I thought the bank 2 thing sounded strange. The anti-fouler trick worked for me, so is probably the cheapest option.
Sarcasm -> look it up
You can also set up the ECU to pass all OBD2 tests if you want to. But the anti fouler trick works, anyone can do it, and it will only cost you $5.
Nastynine
Oct 29, 2009 10:26 PM
