Evo + Rain = better evo ?
...Speeding in the Rain is never good... But driving in the Rain... Ok so after work today it was raining, was taking it easy until i seen a SS truck peel out at a stoplight... So i was thinking how much can i spin from a dig in light rain, I'm about 90% stock and got some tire spin... had it under control so stepped on it a little more while shifting and noticed that my gears were so so smooth like butter, most the time I would have to hold the clutch in a second or two... then noticed I was getting faster spool up too... this all was only after 7 - 10 minutes the car been on from a 9 hour shift. So my question is, why did the rain make me shift smother and spool faster, or am i just crazy??? Hmm... Thanks all in advance
Guess i left out some parts.. =( . i was already going 40-50mph and felt it kick in more then norm. and how about the smooth shifting... it never shifted that smooth at all... i mean went right in to gear, like it was auto...
To the OP, check your front and back engine mounts, they might be cracked. Or, it could just have its moments.
You can't accelerate on jack stands, even at red line in top gear (UK version, not US) you are still going zero mph
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Update... Next morning, rain stopped and now she's shifting like old times, kinda stickie but still shifts... Maybe my clutch line is mostly dry so no smooth shifting and the rain water from the road lubed it up some...
try replacing your front lower tranny mount. im rockn a blox one in my 9.
also try adjusting your clutch,.. do both with a ss clutch line, solid bushings(in car and under hood), bleed your clutch till it comes out clear and toss some AMSoil tranny fluid in your transmission.
Then is should def **** like a dream.
PS Cool dense air.....such as when its raining makes more power than hot dry air.Your butt dyno must be in tune to feel the difference.
