120k service
120k service
I need some help, I dont know what i should do in regards to service. I know i have to do another 60k. Is there anything additional I should do because of mileage.
Mods are:
Full tbe
3.5 Fmic
LICP and UICP
Walbro 255lph
Kelford cams 272
Supertech springs and retainers.
FP RED.
I have 360 on pump.. and 470 on q16. Does anyone have any recommendations on what is needed in regards to service?
Mods are:
Full tbe
3.5 Fmic
LICP and UICP
Walbro 255lph
Kelford cams 272
FP RED.
you did you timing belt at 60k?
I would do the following for 60/120k
oil
tranny fluid
transfer case fluid
rear diff fluid
coolant
spart plugs
brake fluid
bleed acd
timing belt
timing belt tensioner
balancer belt
balancer belt tensioner
water pump
thermostat
idler pulley's
crank seals
accessory belt
cabin air filter
oil
tranny fluid
transfer case fluid
rear diff fluid
coolant
spart plugs
brake fluid
bleed acd
timing belt
balancer belt
water pump
thermostat
idler pulley's
crank seals
accessory belt
cabin air filter
The good thing about the complicated maintenance required for the Evo is that it makes you eyeball all parts of the vehicle. Catching problems before they happen is what makes a trouble free car.
Crester
Toronto Lancer Club
31
Dec 16, 2011 07:26 AM
cs3
15
May 23, 2011 08:48 PM
mmartahus
Apr 6, 2009 12:05 PM
