Stroker kit that is high reving
Old Jan 31, 2011, 06:25 PM
JDM EVO PANAMA's Avatar
Hello I want to stroke but my local friend tells me a stroker kit is worthless if its cutting off at 6500 rpm.
Any good stroker kit that are between 2000 to 3500 that can be high reving.
I saw map has one for 1600 but whats the rev limit on it? and AMS too.
JDM EVO PANAMA is offline
Old Jan 31, 2011, 07:18 PM
Donkeypuncher's Avatar
What are your plans with the car? That might help people to point you in the right direction.
Donkeypuncher is offline
Old Feb 1, 2011, 07:59 AM
Drag Drag Drag
I want to do an HTA3794 eventually but for now im happy with my FS635 kit.
Old Feb 1, 2011, 08:32 AM
SmurfZilla's Avatar
Sounds like you need to get a 2.4L and go long rod config. Even non Long Rods can rev to 7500-8000 rpms.
I think Long rod motors are good to rev up to 9000-9500. That'll spool that 37R as fast as any other config and not be dangerous to spin high in the rpm range.
SmurfZilla is offline
Old Feb 1, 2011, 12:42 PM
Please let me know of some long rod kits that are out there.
I know AMS and Map have good configuration.
Old Feb 1, 2011, 08:28 PM
evolotion357's Avatar
Hmm, I don't claim to know much about Evos but my 2.4 revs to 8500 with no problems...?
evolotion357 is offline
Old Feb 1, 2011, 08:38 PM
awdturbo8's Avatar
If your gonna drag race it,why not just do a 2.0 and rev 9000++ rpm.
awdturbo8 is offline
Old Feb 1, 2011, 08:40 PM
cij911's Avatar
Agreed.
That said the 2.3 can rev to 8500 without issue.
cij911 is offline
Old Feb 1, 2011, 08:46 PM
awdturbo8's Avatar
Originally Posted by cij911
Agreed.
2.3 is more for road racing. If he wants to do a 3794, it would definitely shine and show it's true power with a 2.0.
Old Feb 1, 2011, 08:58 PM
Tuxevo's Avatar
It seems like this topic is discussed once a week. Did you search at all? Maybe just click 'new posts' after waiting 20 minutes and you'll get all the info you need.
Tuxevo is offline
Old Feb 2, 2011, 07:52 AM
agreed, 2.0 for drag
Old Feb 2, 2011, 12:40 PM
EVO8emUp's Avatar
I built a 2.3L stroker for a dude's 91 GVR4 about two years back and he beats the dog snot out of it! It's still going strong and I have his rev limiter set to 7,200, which I'm sure it sees on a daily basis. Hell, I don't even think he changes the oil regularly.
My suggestion, if you have all the tools:
Do your homework.
Buy the right parts the first time.
Check and double check all your tolerances.
Torque all your fasteners properly.
Don't rush.
EVO8emUp is offline
Old Feb 2, 2011, 02:47 PM
ihockey1's Avatar
go look at the bad bish xxx build in the engine section, use that motor and you'll be set
ihockey1 is offline
Old Feb 2, 2011, 02:53 PM
thepoint4life23's Avatar
Buschur is building a high reving stroker. he can maybe chime in or someone else that knows more. but look in to that
thepoint4life23 is offline
Old Feb 2, 2011, 03:15 PM
dabeast's Avatar
buschur long rod 2.4! heres a link to the engine
https://secure.buschurracing.com/cat...8f6847a3d59515
heres also the link to david buschurs build. he had a 2.1 before with a hta86 and ran 9 flat. now is changing it out to a 2.4 long rod with the same turbo to try for 8's.
https://www.evolutionm.net/forums/ev...ld-thread.html
dabeast is offline
Quick Reply: Stroker kit that is high reving
