Chatter/Rattling Noise??
SUSPECTED SCAMMER
sop when i start my car i get this chatter/ rattling noise fcoming from the transmission assuming. When i press the clutch in it all goes away? does anyone know what this is??
is it the throw out bearing?
You have rode the clutch enough to warp the flywheel with heat, you have had a throw out bearing go bad, OR you have a main bearing in the transmission going bad.
I can pretty much guarantee it is not the last thing. The first two are more likely. Just think back when you first heard it and there you have it. You will know.
Do you have a lightweight flywheel?
kstpeter33
Aug 16, 2009 03:34 PM
evosevengsr
May 20, 2004 01:51 AM
