Identify This T3 Turbo
Old Feb 12, 2011 | 12:51 AM
Evokid03's Avatar
Hey guys, had a friend give me this turbo and i have No idea what it is.
What i see, .63 a/r precision hotside w/ what looks like to be a Garret Compressor Side, and regular cast exhaust/compressor wheels.
I honestly have no idea if this is ball bearing or not.
Old Feb 12, 2011 | 12:55 AM
GotWheelHop's Avatar
Looks kinda like a 35r with a Precision 5 bolt hotside. Defintely a Garrett T04s cover. Got a digital caliper to measure the compressor wheel inducer?
Old Feb 12, 2011 | 12:56 AM
Evokid03's Avatar
actually i do, BTW i read these number/letters Scratched into the compressor Housing
PB 400 1551
6776 RS
Old Feb 12, 2011 | 12:57 AM
Evokid03's Avatar
What part of the compressor wheel do i measure? The very outside or the very inside against the blade?
Old Feb 12, 2011 | 12:59 AM
Evokid03's Avatar
I found what it is
400-1551 6776RS Ball Brg .63, .85 A/R
So its a 6776 Ball bearing Precision Turbo
Old Feb 12, 2011 | 01:01 AM
Evokid03's Avatar
So could this turbo be used for a HTA Upgrade?
Old Feb 12, 2011 | 01:02 AM
BenJ's Avatar
This looks like your turbo:
PTE 400-1551 6776RS Ball Brg .63, .85 A/R $1374.99 rated at 780hp
Look on pg 4:
http://www.precisionturbo.net/Pricesheet.pdf
6776 is the answer. That is a 67mm P-trim turbo. Ball bearing.
Old Feb 12, 2011 | 01:03 AM
Evokid03's Avatar
Hmm so its not a bad turbo id say
FYI, that bad boy is a t4 center cartridge, not a t3.
Old Feb 12, 2011 | 01:04 AM
Not at all. That is what FP used to build the HTA88 turbos out of.
Old Feb 12, 2011 | 01:06 AM
Evokid03's Avatar
REally a t4?
Can this turbo be used as a HTA 3794 Upgrade?
Old Feb 12, 2011 | 01:18 AM
No. The 67mm you have uses a P-trim turbine wheel....the HTA3794 uses the turbine wheel from Garrett's newer 37r turbo. It is also a t3 if I am not mistaken.
Old Feb 12, 2011 | 01:23 AM
Evokid03's Avatar
Alright thanks guys^
Old Feb 12, 2011 | 05:37 AM
way2qik's Avatar
I'm a little confused... You're not saying that's a 67mm compressor wheel are you? IOW, if he measures the INDUCER side of the compressor wheel you're saying its 67mm?
It just doesn't look that big to me.
Quick Reply: Identify This T3 Turbo
