Highest Mileage Built motors and turbos??
Old Feb 25, 2011, 08:29 AM
  #76
BLKCarbonEVO's Avatar
Originally Posted by Sharkbite2000
Even at 36psi , you hold that sucker down it will get so hott it will destory itself.
4.11 gears and yes 50psi on the highway will do that
I can't wait to get my 4.11 gears Will be sick on a LR2.4
Mikey
Old Feb 25, 2011, 08:55 AM
  #77
Broham's Avatar
im going to use the 4.11 as well with a 2.4. I dont see a better combo, with a 3794. damn what a street demon that will be. street/drag/texas mile!
Old Feb 25, 2011, 09:08 AM
  #78
Sharkbite2000's Avatar
Originally Posted by Fast_Freddie
Shark loved some 4-5 gear highway pulls... he is a maniac
Who doesn't like it , Nothing like seeing MPH shoot up soo fast you think you looking at your RPM passing 10,000 and then your finally realize your actually looking at your MPH being buried alive
Old Feb 25, 2011, 09:30 AM
  #79
Broham's Avatar
how is the gtr holding uP? no mods i assume?
Old Feb 25, 2011, 09:50 AM
  #80
I was all a dream like B.I.G use to say.
Old Feb 25, 2011, 04:00 PM
  #81
wizzo 8's Avatar
Originally Posted by BLKCarbonEVO
I only run FP turbos and have yet to have a problem, and I push them hard. My Black spins at 160k rpms, the make shaft speed for this turbo is 130k. However I still don't have any shaft play yet
Mikey
How do you know the turbo shaft speed?
Old Feb 25, 2011, 11:23 PM
  #82
Robert figured out a rough shaft speed!
Mikey
Old Mar 2, 2011, 10:54 AM
  #83
Broham's Avatar
I read from a member called riceball who is pushing over 15k with his 3582 on stock block. I'm tempted to try the stock block route at first to see what happens and have a 2.4 on standby
Old Mar 4, 2011, 08:07 AM
  #84
Blkstreak's Avatar
Ivey Built: 2.0 Wiseco, Manley Turbo Tuff Combo.
Turbo: HTA86 mounted on AMS kit.
Runs great, No problems whatsoever. Conservative, 511whp low boost, daily driven. Roughly 8k miles, oil changed every 2500. Not high horsepower or torque, but doing a high boost map tune this year.
Old Mar 4, 2011, 08:23 AM
  #85
Broham's Avatar
were these drop in or had to be bored out, cleaned etc?
Sounds good man, I plan to head to them for my build since they're close by
Old Jul 7, 2011, 06:00 PM
  #86
Broham's Avatar
Sorry for being away but lets keep it alive. Any input as to how strokers vs 2.0s hold up over tIme? Is it wrongful to think the high trq of the stroker might reduce engine life over daily driving many miles? Since the tq is down low. I see good things about the map2.4 but nowadays there are many 2.4 builders. Any body care tao chime in regarding 2.3vs2.4 vs 2.4 lr in terms of engine life. Std compression or 10:1
Old Jul 11, 2011, 06:33 AM
  #87
Hardware's Avatar
Thanks for creating this post. I wish there was more participation at this point. With everyone under 20,000 miles it's making me second guess my build plan at the moment. I assumed built would mean "bulletproof" the setup. I guess it just means you'll be able to get more hp/tq (for a limited time). Learn something new each day.
Might be a good place for me to throw in the towel, get a stock motor thrown in and sell all mods to cover some of the costs.
Here's a great read for 2.0 vs. 2.3.
http://www.scribd.com/doc/30244880/S...itsubishi-4G63
Old Jul 11, 2011, 08:03 AM
  #88
Broham's Avatar
Hardware,
Thanks man. The issue is that there are many options. Most people talk about a built motor like it is the end all savior. This is not true. It's not that it can break, but there is maintenance required since at higher power like mikey said there is more beating on the rods. It depends all on the application also. These guys pushing over 500tq or more are the ones at risk. My questions would be to fill the gaps in the community. Like, what kind of mileage or maintenance is happing on 2.0's vs 2.4s? 2.3s vs 2.1s? Hbeam vs I beam. Instead, you just hear about built motors as the "solution" to the more power problem and nothing more. It's not that simple. Post up folks. I actually really like the stock 2.0, I just don't know what I'll sacrifice if I go to a built motor
Old Jul 11, 2011, 08:51 AM
  #89
TxEvo8's Avatar
I would not build the motor unless you plan on running more than 450tq. If you do build it, it will not last as long as the factory block, period.
I have 134k on stock block and turbo. I've run as much as 375hp, and track it(road race) often. Currently I am at 335hp/355tq and I feel it is as reliable as the day I bought it new..
Old Nov 3, 2011, 12:10 PM
  #90
Broham's Avatar
Yikes, much time has passed but questions continue to come up regarding built motors. Trying to keep it alive here.
For those with built motors, anybody here over 30k on their built motor yet? Any issues? Not really 800tq 900whp builds but more mild like 500- 600, 500tq folks.
thanks
Quick Reply: Highest Mileage Built motors and turbos??
