invidia exhaust manifold + ETS metal radiator hose
does anyone here have the Invidia exhaust manifold and an ETS metal radiator hose? I need to get something so my current hose is no longer rubbing my manifold. i have aluminum foil in between them (yea yea hillbilly fix lol) but its still slowly burning through. i was going to buy the cbrd radiator but if i can save some money by getting the ETS metal rad hose i want to do that. my only concern is the hose will not fit properly because i had to cut a good bit of my samco hose to get it to fit like it does now and it still rubs.
the ETS pipe is a stock replacement, and shares the same general shape as the oem hose. Chances are, if the oem is rubbing, the ETS will either contact the mani or be very close. If you don't want to take that chance, check out JMFab website...they have a nice polished hard pipe with a different design that shouldnt contact any manifold. Prob is a little more expensive than ETS's tho
Here's a link for you...
http://www.jmfabrications.com/store/...-Pipe-Set.html
This is for the upper and lower pipes...I'm sure you could call and order just an upper. See how the pipe only projects forward into the bay just an inch or two? It should fit...
You should be good with our hose, we moved it towards the driver side. Like I said over the phone. We will use you as a test subject If it doesn't fit, we will take it back.
Thanks!
Michael
Thanks!
Michael
the ETS hose did not work for me. I ultimately had to purchase a radiator from CBRD. you could always take your radiator and have the fitting fabricated to point to the side. you cant go wrong with a CBRD product!
TxFAkuma
Feb 17, 2020 11:12 AM
iLLevo_
Oct 20, 2017 12:58 PM
mitchroxz
12
Mar 29, 2013 06:21 PM
booster9
Nov 30, 2008 11:08 PM
