who running 1600cc injectors
How well do they work with the AEM and a 255 walbro fuel pump and should I run 92 octane gas or E85.
Here my motor setup
EAGLE 2.3 STROKER W/ WIESCO PISTONS & EAGLE RODS EAGLE CRANK.
ARP HARDWARE THROUGHOUT THE WHOLE ENGINE
BUSHUR GT35R WITH SS MANIFOLD AND DOWN PIPE
RNR FULL EXHUAST SYSTEM
SPEARCO FRONT MOUT INTERCOOLER WITH 2.5" INTERCOOLERPIPING..
DLI IGNITION & C.O.P SETUP
AFTERMARKET INTAKE MANIFOLD W/ 70mm ACUFAB THROTTLE BODY..
CROWER VALVE SPRINGS AND REATIANERS
3 ANGLE VALVE JOB
1MM O/S SS VALVES
AEM ENGINE MANAGEMENT
ADJUSTABLE VENOM CAM GEARS
TIAL BOV & WASTEGATE
HKS 280 CAMS
Here my motor setup
3 ANGLE VALVE JOB
1MM O/S SS VALVES
HKS 280 CAMS
i cant say that i have them but i heard they work great. the bluemax 1650's i would go with if i were you. they would be enough for e85 but you know your gonna need a bigger pump for e85 and that set up
