cosworth 272 vs kelford 272
hey guys i need some help im stuck on 2 cams as you can see i am gonna get a fp red turbo and i was wondering witch cam would be the best for that set up my friend has a set of brand new cosworth 272 never been used for $300 and im not sure if the kelford 272 are better so if you could help me out i would it appreciate it thanks
This testing does not include Cosworth 272s, but it may offer some great information for you...
https://www.evolutionm.net/forums/ev...-cam-test.html
have you looked into gsc s2's?
No experience with either, but I'd get the Cosworth cams over the Kelford's just because they will make similar power and you'll save more money since you can get them from a friend.
if you want the most power, save up a little bit more or wait for some used GSC S2s.
as far as Cosworth M2s (which is what i have) vs Kelford 272s, they're very close from what i've read. i've been told that valvetrain upgrade is optional with the Cosworths, where it is recommended with the Kelfords. so if the money is tight, go with the Cossies. i don't think you can go wrong either though.
From what I understand both are solid cams, personally I have kelfords and havent looked back once, made 500whp on fp black with them with room to grow~
Just do a little research on phantom knock as your tuner will have that to deal with
