a/c delete serp belt
Old Apr 5, 2011 | 02:15 PM
TommiM's Avatar
Originally Posted by 5 ltr. beater
any benefits to unhooking the a/c and deleting it besides saving weight?
Im mostly doing it to reduce weight off the front end as much as I can. I have been thinking about whether or not to keep my a/c, but after owning the car over a year I only turned the a/c system on 3 times. Twice just to make sure It still had refrigerant in it still.
Old Apr 6, 2011 | 06:32 PM
dg1987's Avatar
Originally Posted by milford
or you can do what i did...go to napa and ask for a 57 inch 5 rib belt. costed me 13 dollars.
Thats exactly what i did. Still works perfectly
Old Apr 8, 2011 | 10:33 PM
TommiM's Avatar
So I installed my a/c delete belt, verified it worked ok and had an appropriate amount of tension. All was good so I evacuated the a/c and removed the compressor, high side line, and the a/c bracket. I did all this after I got off work and just got home from doing this. Next time I get a chance Im gonna finish getting the rest of the stuff off, low side line and condensor.
Just a heads up, there has been some incorrect info on what belt to use, its not a 5 rib belt, you will need a 6 rib belt, the napa part number is 060569, its 57 7/8" long.
Old Apr 10, 2011 | 09:36 PM
awdturbo8's Avatar
How much was the belt from napa??
Old Apr 11, 2011 | 12:23 PM
TommiM's Avatar
$28. I get a discount from our shop, prices may vary depending on area though.
The evo does feel more nimble on the front end and feels really smooth. There is soo much room now with the compressor and bracket out of the way.
Old May 23, 2012 | 08:12 PM
bluebyyouco's Avatar
2003 m3 belt works perfectly for bypassing the ac compressor
Old Jan 10, 2013 | 10:04 AM
xtruemassacre's Avatar
LOLOLOL I add a serp belt for my 03 M3 laying around, then got rid of it when I sold the car to get the evo....DAMN IT! I wish I would have known, but whats $30 lost? Whatever.
Old Aug 1, 2013 | 08:42 AM
2gsxtasy's Avatar
I can confirm the gates belt part number listed above... works like a charm
Old Nov 16, 2013 | 06:07 PM
mike04rally's Avatar
newbie here
So my ralliart is making a weird knocking and smoking and sparking from my ac condenser so I plan on just removing it. I was curious if this belt is compatible with the espoused and if not could I be redirected to a faq or info on my car? Thank you for any advice or help given. It is greatly appreciated.
Old Jun 6, 2014 | 08:30 PM
detroit pistins's Avatar
now that its 3 years since you installed it, would you still recommend this belt? or at least this length? Appreciate the feedback.
Reason why I ask is because my belt tensioner doesn't seem to apply enough tension even at idle allowing the alternator to skip (guessing at this point due to voltage drops!) and also impacting the water pump performance (over heating at times). I do see that it adjusts itself while idling and when this happens the engine sound changes. More or less similar to voltage drop effect on engine noise at idle.
I do have the AC deleted and I am using a shorter belt from a reputable shop but never measured it to confirm.
Thanks for the feedback!
edit: While performing WOT pulls, I experience a drop in voltage to almost 10v and its leading me to think that this maybe related as its intermittent.
Old Jun 7, 2014 | 10:28 AM
TommiM's Avatar
It would be interesting to measure your old belt when you replace it and compare with the gates one I listed above. Some of the parts stores have a belt length measuring device, usually up on the wall by the belts, too so that may make it easier if your already there to pick up a belt.
Old Jun 7, 2014 | 11:59 AM
Biggiesacks's Avatar
Sounds like your battery is going bad too, or you have some dirty connections. the battery should be able to keep it at 12v.
Yabdiel Torres
Jun 22, 2017 06:32 PM
evochongi
Oct 18, 2016 06:20 AM
eisnikesb
May 12, 2014 10:24 AM
Alfordz123
Aug 29, 2013 08:50 AM
tseitz123
18
Aug 12, 2010 10:45 AM
Quick Reply: a/c delete serp belt
