Beatrush Front Plate Mount
I searched multiple threads and couldn't find a direct answer. I just wanted to know if the Beatrush Front Plate Mount requires that you drill into your bumper. I know it uses something with the tow hook, but does it need to be drilled on anywhere else? If you guys have info/pics on how it's mounted that would be great!
Thanks,
Brendan
Thanks,
Brendan
I just installed mine on my X, it used the stock mounting holes to the the OEM license plate bracket.
I looked at the IX stock plate location and the beatrush. I assume its the same.
Didnt have to drill anything at all. Kit comes with all mounting hardware. I used the instructions that it comes with. Some areas are not fully clear on what harware to use wear, but when you lay everything out, you can figure it out. Although i did not weld the middle bracket to my intercooler. Just running w/o that one backet installed Also note that in my case, my downpipe hits the plate and rattles a bit, no other issues with it. Its a pretty nice piece
hollywood
Jul 14, 2003 06:11 AM
