tcase leak...
tcase leak...
Recently i've noticed a small leak. Jacked up the car and saw that i had a small leakage from my tcase. I just can't determine what is causing the leak. Can it be a bad washer or bad seal? Would there be anything else that would cause the leakage?
thanks!
thanks!
where is it leaking from on your trans case? from where it bolts to the tranny or where the axle slides into it?
like ^^ said, it could be either of those 2 O-rings or the axle seal
i replaced the smaller and larger o ring to the t-case. looked at it again yesterday and it seems to be leaking from the driver side axle... but i replaced both axle seals also. so i have no idea what else it can be.. probably should pull off the axle again and see?
