snapped three head bolts
Use a new head gasket now that that one has been compressed as well. Also for arp studs install the studs tighten head down with old gasket in 3 step sequence to spec, loosen in 3 step sequence then remove bolts and head, install new head gasket then tighten to specs in 3 stage sequence then you should be good to go assuming your deck surface and cyl head are flat. good luck.
I feel bad but it seems like you created the problem yourself. Take the head back off and see what's left of the bolt. Then get a manual to help you assemble it by the book. Make sure you clean all the holes, as someone had asked. Having debris on the bottom of the bolt holes will cause this problem if the bolt bottoms out before getting tight on the head. Might also wanna check you torque wrench for accuracy.
first, why are you even tightening the head bolts in that pattern, i posted the pattern for you yesterday and you still just go and tighten them in the wrong pattern. at least its your car, not mine.
second, YOU NEVER REUSE HEAD BOLTS
should've just did headstuds why the head was off and had the extra reassurance also
The head bolts are designed for torque to yield. In other words you are near breaking them when they are torqued properly. While this is the strongest way to go it makes the bolts one time use only.
It may only be necessary for high psi hp set ups. either way that is the route to have the job finished correctly the first time. but the way this guy sounds, To me it sounds like he more than not will be having other issues as well after the head stud issue is resolved for example head may be bent slightly cracked be it whatever if you don't install vital engine components without properly checking things out / machining when necessary to get in correct tolerances, You're more likely than not going to fail at your set up possibly installing things " Blindly " under your backyard tree you may be using for shade.. lol
Were you reinstalling stock headstuds that have been used? You shouldnt do that
You should have stopped at the first head stud that was causing you problems.
Also you have to watch what your doing to make sure the bolt is going in strait and not cross threading
another thing to consider too op is to make sure your torque wrench is actually torquing at the lb/ft it says it is....you can take it to autozone or another parts store, and some of them have a display where you can check the tq spec and make sure what your wrench says it what it is...your best man, tow the vehicle to a pro shop, and youll pay out the *** but at least itll be fixed in the end, sounds like some drilling removing and tapping some head to block threads will be in order, well if that be the case, then might as well have it done by a pro have the new block threads be able to accept the L19 arp head studs...good luck op
In support, I have reused my ARP headstuds on my VW at least 5 times
In my experience in joint design yield bolts are used in clamp zones that change height/thickness (reducing clamp force) because of compression from gaskets or from softer materials that crush... IE, headgasket
