Double Pumper and Gauge problem
I installed a buschur double pumper and barely made it to the gas station with the gauge on empty and fuel light on.
Filled the car up and everything has been going fine for about 500 miles. This week took the car to AWD to get it tuned and the gauge read 1/4 and it ran out of gas. Glad I had an extra can in the car to get me there. On the way home I was curious to see what it would do so I ran it as far as I could it made it just below the 1/4 mark on the gauge before it ran out again.
Is there a way to adjust so my gauge will read right and is this a common issue?
thanks in advance sorry for the long story.
not really sure ttp did the install. I am going to look in the tank this weekend to see what I come up with and take come pics. What i find strange is when I first picked up the car and drove the car to the gas station it was reading empty and I made it to the gas station fine.....but not I cant get under 1/4 without running out of gas.
definately sound like the floater may have been accidentaly bent. pulling that thing out to check it wont be fun. those supply hoses make for a tight fit in a small area. good luck . report findings
Double Pumping
Try Buschur's web site for a how too or do a search on here or High Boost Forum. I know there is a great write up on the install with pic's. Good luck.
Btw way I did a little cut here and there around the housing to help get the pump out. Also, I recommend making sure the second pump has a good ground. I grounded mine to the frame.
This sounds more like the siphon is not installed. Remove the fuel pump basket and make sure the small "t" shaped plastic insert is installed.. if you got a bag of parts back make sure it is not in there.
This piece is what gets the gas from the passenger side of the tank to the driver's side. Without it, you will run out of fuel but the passenger side will have gas in it.
This also would explain why you made it to the station on E when you got the car back, the siphon would have been doing its job before the new setup was put in.
I would at least check that before bending the float, I had the problem you describe as well and that was it. Also, sometimes the "filter sock" can be in the way of the float falling all the way down, they would just need to be turned a little to clear the float
https://www.evolutionm.net/forums/ev...ould-know.html
I don't have pics though, it would have the small plastic fitting, with a length of rubber hose on both top 'ports'..
BOOSTINAT30PSI
54
Jun 28, 2012 10:27 AM
1badgsex
Jun 26, 2012 01:46 PM
way2qik
Apr 14, 2012 06:40 PM
David Buschur
19
Oct 9, 2009 07:10 AM
