Boost Issue
Well, before things even get worse especially in arizona heat, you should go to the local tuners and have it all done at once, boost leak test it and retune. If you have the evo 9 DV it shouldn't sit wide open if I recall, if it was does it even build boost?
Yes builds boost really quickly, seems fine in first but second gear on it boosts fast if hit gas, have to stay out of it and builds rpms as long as doesnt get any more than 5psi boost, if it does it hits fuel cut from over boost
I also found a cracked silicone coupler that went from turbo to the front mount on the hard piping. Car is up and running great right now but seems to want to try and stall out when go into idle, never did that before. Its only when first shift into neutral and dropping the rpms
