Hard to Shift at High RPM's
Old Jul 23, 2011 | 03:07 PM
erald01's Avatar
exedy single plates are known for lock up issue, go for exedy dual clutch or ACT HDDS.
Old Sep 27, 2013 | 04:27 PM
HDA's Avatar
HDA
I am having the same exact problem, this weekend I will replace the shifter bushings and adjust the pedal...WTF
A shop told me it might be time to change the clutch but it does not slip so I do not see why would I...
Old Sep 27, 2013 | 07:51 PM
hiboost2.0's Avatar
Do you have launch control set up? If you do, disable it through ecu flash. Go to a flat paved area, hold the clutch all the way down with the car in first gear. Now rev the car up to around 6.5k to 7k, if the car creeps forward at all you have clutch drag. You need to have your clutch pedal adjusted outwards to give it more throw. Also you don't want it adjusted out too far otherwise there will be constant pressure on your TOB which will cause your clutch disc to start to slip prematurely.
Old Sep 30, 2013 | 01:20 PM
HDA's Avatar
HDA
Thanks, I tried to rev the car up at 7k in 3rd at 50mph and it did creep a bit but then it went away and it would rev freely without moving forward.
I guess I need to adjust it a bit. I have an ACT clutch.
Old Sep 30, 2013 | 02:00 PM
hiboost2.0's Avatar
At 50mph? You have to do this stationary on a flat surface in 1st gear.
ACT has been known to have high rpm lockout. They are very sensitive to the clutch adjustments I remember awhile back some shop on here would adjust it for free for you if you had an ACT clutch and were local. I'm putting my money on that you need to give your clutch pedal more throw by adjusting it.
Old Sep 30, 2013 | 09:13 PM
J Woody's Avatar
im having the same issue. it grinds when i go into 4th and 5th almost every time and it will not go into gear over 6500 rpm's, also kinda notchy. I have adjusted the clutch pedal a little more out because the "catch point" was 1" away from firewall. its about 1/2 way now. I also bled the clutch and got some air but not too much. AND i STILL get the grinding and the lockout over 6500 rpm's. my plan is to get the under hood shifter bushing and if that dosnt fix it im gonna be pretty angry due to the fact when i bought the car i was told it had a "comeptition clutch" installed 10-20k mi before i bought it
Old Oct 1, 2013 | 02:57 PM
hiboost2.0's Avatar
Do the test that I have stated above and report back.
Old Oct 2, 2013 | 11:22 AM
J Woody's Avatar
I don't know how to disable launch control, I don't have tatrix cable. But it's set at 6500 and car doesn't move at all.
Old Feb 17, 2014 | 02:29 PM
J Woody's Avatar
still having the same problem, car jumps forward in gear when stopped. how do you fix clutch drag? i have bled the clutch, adjusted the pedal, bought shifter bushings. any other ideas before i have to pull the trans/clutch?
Old Apr 6, 2014 | 07:56 PM
dl100489's Avatar
cheak clutch fluid ,cheak underhood bushings if not replace clutch
Old Apr 7, 2014 | 08:26 PM
Thore's Avatar
Get a 1 piece SS braided clutch line, It does wonders for aftermarket clutches.
I've gone 40k on my act hdss. On occasion I would get locked out, but since installing the clutch line I have had nothing but great results. It's relatively cheap too.
scheides
Mar 1, 2014 09:45 AM
YIfuEVO
Jan 4, 2014 07:42 PM
Lucas English
126
May 25, 2012 04:46 PM
waterlooLancer
26
May 17, 2012 08:55 AM
johnnycage
20
May 11, 2012 01:20 PM
Quick Reply: Hard to Shift at High RPM's
