front lip hardware??
Does anyone know the part numbers for the front lip hardware. I dont have a undertray and will need the clips or bolts to hold the se lip to my front bumper. If someone has the part numbers for this or someone has recently bought something that worked good at a local auto parts store that would be great to hear what you used.
thanks
thanks
if you took your other lip off, you would have the hardware neccessary.
And it bolts into the plastic studs that are plastic-welded to the inside of the lip (refer to your your current lip for the example).
If your SE lip does not have the plastic studs then there is nothing you can do aside from some seriously janky self-tapping screws through the outside of the lip.
Here's the part #'s from mitsuparts:
Rivets 14, (6407A017),
Clips 6, (MU488006),
UT Clips Look, (MB547806)
But like other's mentioned this is for fitting an SE lip to a IX bumper...
Good luck!
Good luck!
ersuley
Sep 6, 2017 07:39 PM
2010evoxgsr
Jun 22, 2017 11:41 AM
