Intercooler sprayer
I would like to see some actual data that the ic sprayer "doesn't" work as in dyno pulls back to back with it on and then with it off. I doubt it would be much but it has to be a little, and as for weight taking it out I wouldn't think would yield much either since I have heard, not proven, but heard that generally 100lbs taken out= -.1 tenth off ur quarter mile time. If that's true ten pounds really doesn't matter that much so I could see it going either way.
I also had a thread about replacing the ic sprayer water with the nitrous express ic sprayer bar and spraying nitrous across the ic instead of water. Anyone think that would yield significant gains or did any testing on that? They claim a turbo civic picked up 50hp from that alone kinda hard to believe, but never seen anything disproving it either. If it would yield significant gains I would run one and wire it into the stock ic sprayer button to work as "oem" where it sprays for 2 seconds every 3 seconds on auto and sprays continuously holding down the manual side. Any thoughts on this?
Even if it takes a 100lbs to get .1 tenth off a quarter I doubt the IC sprayer will give that much. And since you are talking about the track there are plenty that would rather get rid of every pound they can. Most guys running the track and going for weight reduction I would bet are getting more out of losing that and other stuff than keeping it.
As for the average evo driver it is a waste of time really. It is in the way of a great area to get cooler air to you intake. In the year I had mine on and had it on auto it never once sprayed. It worked it I used it manually so I know it worked.
I would think if you used it to spray something else that was cold it would work better. I have doubts though on picking up 50 hp maybe closer to 5hp and stretching it 10hp.
Not saying the IC sprayer does not work, just saying I think the gains are minimal and was most likely just a selling point. If you notice they ditched it pretty quickly so it was most likely a crap idea to start with.
I would like to see some hard data though on say spraying liquid nitrous on it or even something similar. I think that is where you would get real gains.
I dont mind it, i see no point in taking it out for a street car. I wonder if spraying a water/alcohol mix would have a better cooling effect? I did however spray mine on manual for several seconds in front of a buddy and he says "Hey man your radiator is leaking", i just laughed
The programming for when the sprayer comes on in the automatic mode is complicated and it does it basically to protect the engine not make the car faster. Well, if protecting against knock makes the car faster, it does that. Its a nice feature to have. I wouldn't throw it away.
I do manually hit mine when I'm driving on the highway on during the hot summer days/nights.
I ran the first session w/o spraying and by the end of the session I lost 4mph on the longest straight (around 85 degrees). The second session I sprayed and only lost 2mph at the end of the same straight by the end of the session (90 degrees this session).
So.... Does the IC Sprayer bring about any power gains? Minimal at best.
Does the IC Sprayer allow you to hold power longer deep into a track session? Absolutely.
If you're plans are to drag race the car.... ditch the sprayer. If you plan on doing any road course driving.... keep it.
I use windshield washer fluid in mine while I am at the track - road course. It evaporates much faster and pulls the heat off the bars faster than water alone. It definately helps in keeping the charged air cooler for longer over a 20 minute track session. I don't have any logged data to show but from the last time I was on track I did one session w/o spraying, and ones session with spraying.
I can understand, agree, and accept the other points.
It's usefulness depends fully on the use of your car.
It might be worth pulling out the pump, and flushing some fluid through,
(my sprayer was not working either)
You should mod yours to spray the water directly into the turbo. Huge power gains.
As for the weight, water weighs 8.34 pound per gallon, so figure out the volume plus the weight of the jug and you can tell your weight savings. Anything that evaporates quickly (or quicker than water) will cool quicker - methanol (often in washer fluid, especially the winter de-ice version) rubbing alcohol, etc will evaporate very quickly pulling the heat out more efficiently. put a little on your skin and feel the cooling effect as it evaporates quicker than water - of course that isn't exactly good for your skin.
how about routing an a/c duct to the intercooler ?
