CAM Install pictures....
oddly enough againts most of what is seen here on this forum we did not bleed the lifters however not all installs are the same we got a break and it was a simple swap i imagine that if we had done the valvetrain then I would have bled them....
well... take the results for what they are worth but I went in there and made 305whp/295tq as a baseline pull with all the modifications but with a tune for everything but the cams on 91 octane. Tuned for all mods on 93 octane I left with 350whp/310tq at 23 psi. It feels like a quick 350whp (not sure if the dyno reads low). What I am really happy with is the driveability of the car now, and also the mid range power of this car is awesome.
Going to run a compression test on Monday to find out if the motor needs a rebuild any time in the near future. There are also no boost leaks whatsoever.
^^^for the 23 psi its not bad remember I was running 26 peaking at 28Psi on 91oct, I dunno why he didn't tune for more maybe 25psi remember it does have head studs, but as long as the car is healthy and your happy then its all good.
Jossue
Evo X How Tos / Installations
May 6, 2012 12:15 PM
eyekyu
Mar 11, 2009 02:49 PM
