Have a problem
Have a problem
Okay my seatbelts light the srs light is still on. Now I had my seatbelts reset but I plugged them in then connected the battery. I go to sit in the car my seatbelts lock. Once in awhile my drivers seatbelt has a hard time retracting and I had the passenger side reset and its still locked.
Yes I have the seatbelts were a problem before but I sent the seatbelts out to get reset. Now instead of them being loose and not retracting now they are just stuck in the rolled up position wtf is goin on the car dont want me anymore or something lol? what gives?
Okay I understand what your saying guys I will definitely try to do what I can amazingly the seatbelts are now working again. Except the passenger side and I just recently had the passenger side reset.
Where are the plugs that plug into the airbags? I know there is one into the dashboard,theres one in under the steeringwheel and one on each seatbelt which I both connected. Now what?
I think your best bet will be to bring the car to a dealer so they can scan the srs code so you know exactly what is happening. Once you know what the code is, come back and post it here for help troubleshooting it.
I think there is an wiring connector under the seat for the seat belt warning buzzer or something, that gives you the emblem on the dash if you drive without a seat belt. Sometimes those connections get loose. Look under your seat and disconnect, clean and reconnect any wiring connections going to your seat belt.
