How do you take rear seatbelts out?
striping the rear of the car. im putting in a autopower cage. but i cant figure out how to take the seatbelts out? any help would be great thanks
kevin,
kevin,
used this post from boom29UPDATE!
I wanted to primarily remove the rear seat belts. Turns out they are a bit difficult to get to, but I was wanting to gut the rear of the car anyways so it wasn't a bid deal for me.
I made some note to share with all. I don't feel like going into detail since it was pretty straight forward. So, take your time and use common sense for the most of it. If there's a trick, I noted it:
- Remove rear seat; 2 pull clips
- Remove reat seat backs; lower seatbelt hardware and corner bolts
- Remove speaker bolts (from trunk) (3 each side)
- Remove 3rd brake light nuts (2 total) 10mm
- Remove child safety harness bolts (3 total)
- Remove c-pillar (only need to remove one side)
- Remove speaker covers (2 total)
- Remove/dismantle 3rd brake light; twist bulb assembly 1/4 turn and remove cover
- Pull out rear deck around seat belts - be gentle; it's on clips, so take a screwdriver covered in black tape and rub behind to pop free
- Pull out rear deck rubber padding - be gentle; it will tear
- Remove seat belts (3 total)
write up helped alot
