Driveshaft Part help
Hey guys so had my car on the lift the other day and noticed i could move my driveshaft pretty easily. the carrier bearing seems to be worn out the one that is round and holds the driveshaft in place. it is the one that is under the drivers rear door. anyone know a place i can get this? i wasnt able to find it anywhere on the sites i know. and im not sure if it is even called that carrier bearing so i might be looking for the wrong thing. any help is much appreciated thanks!
I'm not saying that you are wrong but the carrier bearings are mounted in a soft rubber. If you pull on it, the drive shaft will move a surprising amount even on a new car.
http://www.akadia.ru/_pages/mitsubis...MDAxNi5qcGc%3D
MR553201 CENTER BEARING,PROPELLER SHAFT,FR
MR553202 CENTER BEARING,PROPELLER SHAFT,RR
Each bearing is $44.51 + shipping on Mitsubishiparts.net
Hope this helps
Hope this helps
Hope this helps
Hope this helps
that helps alot but are you positive thats what i need? i dont see the part number on it in the picture? im gonna take a picture of it tomorrow and how bad it moves and just to make sure that thats the part i need thank you for the info hopefully this helps
cficare68
23
Feb 19, 2021 11:09 PM
antilag_200
17
Jul 31, 2013 05:12 AM
smokedmustang
33
Aug 16, 2012 10:35 AM
