UICP blew off = CEL on?
So as I was driving on the freeway yesterday my UICP blew off (2nd time!) The first time it blew off last month the CEL did not come on. But this time it's been saying 'Service Engine Soon' since yesterday...
going to autozone to get some t-bolt clamps too much boooooost!!!
where did it pop off on the tb?, if so spray a bit of hair spray only on the outside of the tb, securely fit the coupler back on give it a min or two to stick, then tighten the clamp down. If your using a tbolt clamp, make sure you have it over the lip of the edge of the tb. good luck, buy a code reader from autozone, i think mine was like 40-50, itll tell you the p codes and you can clear them with it. good luck.
if your going to autozone for the clamps just ask them to use the code reader, and read the code then erase it. simple as that. Just had the same thing happen to mine 26psi stock clamps wont hold
went away after a day of driving... I figured there was nothing wrong just wanted to make sure...
autozone didn't have t-bolt clamps... gonna try lowes or something
