need help with aem air fuel ratio
i changed my battery for first time on a 2006 gsr going on 52k miles now the gage its about year and half old the problem is that after the battery swap the gage sits at 14.7 and dont move at all its like if i lost connection with the o2 can anyone help or tell me what this is ? thanks in advance
I've had this problem before and the gauge itself was bad. It had shorted itself out im not sure how but AEM warranted the piece without an issue. I would definitely check the connections first though. There is a youtube video of a guy showing you how to determine whether it is the gauge or the sensor. If all of your connections are good you may check it out. You should be able to turn the key over and not start the car just to the on position and the gauge should start at ~14.7 and creep up to 15,16,17 etc and eventually have dotted lines. If not then there may be an issue.
i checked all my connections and they are all good and when i turn the key on the on position i get the numbers 111..222.333. ect. but then stops at 14.7 and it wont go to ---- so is it the gauge or the sensor i just dont wanna buy the wrong stuff im going to do the brake clean test and see what hhapends ill keep u guys posted
cerealkeller
Jul 22, 2016 12:09 AM
Gage201
Oct 20, 2008 07:32 AM
Nvr2old32
Feb 15, 2006 05:19 PM
