Kracka Crankcase Vac. kit...
I was in the process of installing this and I think it might already be on my car (in some form). Im goin to try to post a pic. Idk where this piece came from, but it looks like the valve in the kit. When you blow through the big end of this one it opens and closes if you blow through the small end. Thanks
Yes, you need both. (Well...sort of ) If you use only the MAP check valve, your idle will be way too high because the airway is much larger than the oem pcv valve. If I recall correctly, mine jumped to about 2000 rpm. I installed the MAP check valve between the pcv and the intake manifold, and the idle returned to normal. And yes, it is a tight fit, but both valves will go in that small space.
I suppose that if the air flow of the MAP unit could be reduced to match that of the pcv, then you could use just the MAP. Or, maybe the excess air could be compensated for at the throttle body. I'm no tuner, so I didn't attempt to go that route. I'm certain that some other members here would know the answer. Good luck!
I believe that tscompusa2 has addressed the entire issue of blow-by, and crankcase vents very thoroughly. ( Search for his posts under "crankcase vents"). I'll be following his mods and recommendations for this Winter's project.
gullie667
23
Mar 17, 2009 08:10 AM
alloutDSM
14
Nov 3, 2008 02:00 PM
Evo8Emperor
Oct 17, 2007 07:32 PM
Derek888
31
Nov 3, 2005 02:36 AM
